DELFTship - programek pro 3D modelovani lodnich trupu
dodo
Příspěvekod dodo » úte říj 23, 2007 1:27 pm
Zdar,
posilam neco na hrani na dlouhy zimni vecery :). ...narazil jsem na peknej programek (zadarmo :)) ketrej umoznuje napr. konstruovat trup, visualizovat, provadet hydrostaticky a jiny vypocty a spoustu dalsich veci.
Jmenu je se DELFTship a je zdarma ke stazeni zde. ...jedna se o nastupce programu FREEship.
...a co navic - neni to jen pro konstruktery novych trupu ale ma dobrou podporu pro prevod vasich existujicich planu (napr na papire ci jpg) na 3D model a na nem pak provadet ruzne vypocty. ...jednoduse se na pozadi toho designeru nahrajou vase plany a vy pak jenom "pretahate" prislusne body modelu podle toho pozadi a je to. ...na tech strankach je k tomu i podrobny manual "krok za krokem"
dodo
na strankach pisou toto:
DELFTship™ is a complete design package for application in the marine industry. It is characterised by its ability to create any kind of hullform, high flexibility, low learning curve and visual approach. It can be used for almost any kind of floating object. The basic hullform program is free for all users. Additional extensions are available for the professional user.
DELFTship™ uses subdivision surfaces to model the hull rather than NURB surfaces. Most hull modeling packages use these parametric spline surfaces which can be very tricky to use. Subdivision surfaces offer many advantages over NURB surfaces, such as:
No need for a rectangular control grid divided into rows and columns.
More freedom in modeling knuckle lines.
Surfaces can contain holes.
Even the most complex shapes can be created with just one surface.
The possibility to insert just one single control point.
All hydrostatic calculations are carried out using surface integrals. This results in a more accurate assessment of hydrostatic properties compared to the more traditional method of integrating cross section areas.
Marty
Příspěvekod Marty » stř říj 24, 2007 7:44 am
Ten odkaz nějak nefunguje, je to určitě on?
stefin
Příspěvekod stefin » stř říj 24, 2007 8:37 am
Mi odkaz funguje, ale nezda se mi, ze by program byl zdarma.
marianb
Příspěvekod marianb » stř říj 24, 2007 9:20 am
Je nutne se zaregistrovat a pak se da nejaky program Free stahnout.
dodo
Příspěvekod dodo » stř říj 24, 2007 9:43 am
me teda odkaz funguje bez problemu.
FREE je to urcite taky - mam to stazene a zbezne jsem to zkousel.
co FREE neni jsou dalsi plug-ins moduly:
Load cases
Critical points
Cross curves
Tank modeling and calculations
dodo
dodo
Příspěvekod dodo » stř říj 24, 2007 10:41 am
Jo to jsem zapomnel zminit - je to jak pise marianb. pro stazeni (at uz programu nebo dokumentace ci tutorialu je nutne se zaregistrovat)
...kdyz chcete jit do sekce download tak tam zdanlive nic neni je nahore je takova nevyrazna/snadno prehlednutelna hlaska ze je nutno se nejprve zaregistrovat.
ta registrace je ovsem take zdarma.
Reputace: 116
Příspěvekod Libor » stř říj 24, 2007 11:09 am
To dodo
Tak to nahrej sem, když je to free a ať se nemusíme tam všichni regnout ;)
dodo
Příspěvekod dodo » stř říj 24, 2007 11:20 am
neni problem, ale musis me navest jak na to.
kdyz jdu do sekce "Ke stazeni" a chci dat "Nove" tak mi to pise ze tem modul neni aktivni :(
jak to tedy uploadnu ?
Příspěvekod jerryx » stř říj 24, 2007 11:40 am
dodo píše:neni problem, ale musis me navest jak na to.
uz je to v poradku - uz jsem z toho hotovej, to uz je potreti co to musim znovu aktivovat :?
akorat misto nove dej pridat .. ;-)
marianb
Příspěvekod marianb » stř říj 24, 2007 12:54 pm
Libor píše:To dodo
... pak to bude ke stazeni pouze pro pokrocile.... :roll: , uz ne tak free.
Reputace: 116
Příspěvekod Libor » stř říj 24, 2007 1:00 pm
marianb píše:... pak to bude ke stazeni pouze pro pokrocile.... :roll: , uz ne tak free.
Pokud tu nebudeš chodit jednou za 1/2 roku, tak budeš pokročilý zachvilinku :D
A samozřejmě je vždy možné u každého souboru nastavit free nebo pokročilí.... ;) , v tom tedy problém nevidím. Práva si volí ten kdo nahrává / dává soubor...
dodo
Příspěvekod dodo » stř říj 24, 2007 1:17 pm
tak jsem prave uploadnul tyto soubory
delftship_free_31_setup.exe
Manual.pdf
Trace demo.zip
Tutorial01.pdf
Tutorial02.pdf
je to v "Ke stazeni" v sekci software - zatim to tam ale jeste nevidim, asi to ceka na nejake schvaleni
p.s.
jeste mam DEMO PROFI verze tohoto programku. Mam to sem data taky ?
dodo
Příspěvekod dodo » stř říj 24, 2007 1:21 pm
Libor píše:
tak tuhle moznost jsem tam nevidel. na tom formulari jsou piuze tyto pole :
Název:
Povolená přípona: URL:
Souhlas k použití: Ano Ne
Zvolte kategorii:
Popis:
Vaše jméno (nick):
Váš e-mail:
Verze:
Hlavní stránka:
jak to tedy lze udelat ?
....ja bych to jinak totiz jako free dal protoze ani ja nejsem podle mistniho bodovani pokrocily :( ...ale treba jednou budu :)
Marty
Příspěvekod Marty » stř říj 24, 2007 1:30 pm
Díky, už to funguje, ráno to asi chvíli nešlo. Zaregistroval jsem se, stáhnul nainstaloval, žádný problém s tím nebyl.
Je to pěkný prográmek.
Příspěvekod jerryx » stř říj 24, 2007 1:31 pm
to se libor trochu utnul - ono to tam totiz neni ;-) o pravech rozhodujou jen admini 8)
Reputace: 116
Příspěvekod Libor » stř říj 24, 2007 1:42 pm
Utnul neutnul. Co brání poskytovateli po nahrání souboru, aby požádal adminy o omezení, nebo naopak zpřístupnění souborů všem :?: :?: :?: :?:
dodo
Příspěvekod dodo » stř říj 24, 2007 2:15 pm
fajn, kdyz je to tedy takhle :) tak timto zadam adminy aby vsechny soubory co jsem uploadnul byly pristupny vsem.
....at si uzijou i ti to nemaji dost bodu stejne ajko ja :)
....koneckoncu na tom zdrojovym webu to je pristupny vsem tak nevidim zadnej duvod proc by tomu melo byt tady jinak.
diky
dodo
Příspěvekod jerryx » stř říj 24, 2007 2:18 pm
dodo píše:fajn, kdyz je to tedy takhle :) tak timto zadam adminy aby vsechny soubory co jsem uploadnul byly pristupny vsem.
diky
dodo
no jo, ale chybi ti na te zadosti kolek :lol:
... dyt uz to davno je 8) (teda jestli si neuploadoval jeste neco jineho)
Příspěvekod jerryx » čtv říj 25, 2007 4:41 pm
2 marianb:
Libor píše:
Nevidim smysl v tom, abych pokazde, kdyz navstivim tento web, jsem pridaval komentar vzdy a ke vsemu jen proto, ze stoupne muj bodovy kredit. A bude videt jak jsem aktivni, jak casto sem chodim, a mohu byt po zasluze odmenen. :D
Mozna se mylim, ale nemyslim, ze vsechno ke stazeni na tomto webu je od puvodnich autoru, tedy orig. majitelu dusev. vlastnictvi a proto se mi zda ponekud podivne nekde neco vygooglovat, povesit na web a pote nastolit hierarchii pristupneho pro skupinu, ktera ma zasluhy - bodiky. (Pravda, pokud si zalozim nejaky spolek, server atd. mohu si stanovit pravidla jak je mi libo, do urcite miry.)
Holt mi nebude doprano, byt si rad prectu uzitecne informace z fora.
Abych jenom nehanil. Mel-li by se nejak hodnotit aktivni pristup, tak take nalogovani, uz to je projeveni zajmu. Neznamena, ze musi hned neco komentovat. Navrhuji nejake body za nalogovani. :mad:
:admin: tento tvuj prispevek jsem smazal.
1, takto se body opravdu neziskavaji
2, moc dobre vis, ze se to resi jinde (v jinem vlaknu)
3, a uz vubec nechapu co to je ? kopie s jednou pridanou vetou ? :evil:
marianb
Příspěvekod marianb » pát říj 26, 2007 9:22 am
... to nemohu tusit, kdyz se nenamahas alespon o tom informovat.
... body jsem se nesnazil ziskavat ani kdyz to bylo nutne, tak jsem do 89 strihal a ohybal draty. Pouze jsem vyjadril svuj nazor, to se tady nesmi? :(
Napsal jsem alespon nejaky podnet, pravda zrejme uz mel byt v jinem vlaknu, ale plynulo to ze situace.
... nevim (tady se pletes) prispevek jsem vlozil, myslim, do kontextu, tak mne v tu chvili ani jine vlakno nenapadlo, ano ma neznalost, holt novacek na foru, to mluvi za vse... :mad:
... mailem jsem se ptal Libora Stacha, jestli mi prispevek nesmazal, nebo jsem udelal neco blbe, tady je s dovolenim odpoved:
"Ahoj,
příspěvky se jen tak nemažou. To byla chyba asi někde jinde. Takto na dálku nemohu posoudit. Teď jsem online, zkus vložit příspěvek znovu a uvidíme.
Tak jsem prispevek vlozil jeste jednou, ne kopii (nenapadlo mne, ze bude na smazani), proste jsem se to snazil napsat jeste jednou, tudiz to nebylo identicke. Ted uz to chapes? :roll:
Tak jsem asi prekrocil hranici "jen tak" pro smazani. (Rekl bych, ze je dle Tvych meritek dost nizko). Neco mi to pripomina.... Ted uz Ti zbyva jenom zablokovat mi pristup. Je potreba vse utipnout v zarodku. :good:
tabyCZ
Příspěvekod tabyCZ » úte lis 13, 2012 6:27 am
Omlouvám se, že vytahuji tohoto kostlivce, ale rád bych podotkl, že program DELFTship je dostupný již ve verzi 5.21.
Vedle toho existuje volně ke stažení jiný nástupce původního FREEshipu a to FREE!ship Plus, který je ke stažení zde: FREE!Ship Plus.
DonEmilio
Příspěvekod DonEmilio » úte lis 13, 2012 7:10 pm
Ten FreeShipPlus mi připadá vstřícnější, než Delft. Dovolí mi i tisknout a má češtinu, kterou jsem u Delftu nenašel. Porovnával jsem teď asi 5 minut. Jinak jsou si HODNĚ podobné.
tabyCZ
Příspěvekod tabyCZ » úte lis 13, 2012 7:20 pm
Češtinu mají 100% oba, protože jsem je oba překládal já. 8)
Zásadní výhoda placené verze DELFTshipu je to, že umí automaticky vyhlazovat povrch. To FREE!ship Plus neumí a při návrhu trupu je to k nezaplacení.
Na druhou stranu výhodou FREE!ship Plus je rozložení obšívky a její uložení jak do *.bmp, tak i do CADu. To sice umí DELFTship také, ale opět jen placená verze. Free verze DELFTshipu rozloženou obšívku uloží jen do *.bmp.
panak-ml
Reputace: 7
Příspěvekod panak-ml » úte lis 13, 2012 7:31 pm
Než to zkusím nainstalovat, tak mám otázku. Jak to umí různé profily kormidel, kýlů? (free verze)
A Delftship už mám nainstalovaný z dřívějška, ale bez češtiny :cry: , kde se dá pořídit?
tabyCZ
Příspěvekod tabyCZ » úte lis 13, 2012 7:40 pm
Je tam na to průvodce návrhem kýlu a kormidla. To je víceméně stejné u obou. ;)
U DELFTshipu doporučuji stáhnout aktuální verzi (v. 5.xx). čeština je ke stažení jako samostatný soubor v nabídce Downloads -> Language Files (nutno se přihlásit). Čeština ve verzi 5.xx umí již háčky a čárky. 8)
Alternativně ji mohu zaslat nebo někde vyvěsit.
